Crimson 3 - Force Tag Read From 5370 Compactlogix
califflash
Jan 2011
Houston, TX
257
Is there any way to force a group of tags or folder of read only tags to read and update their values from a target device? Such as an inverse of the WriteAll() function?
I am currently working on a faceplate for a red lion g310c210 to display and modify parameter data from powerflex 525's. I have a list box that you can select the parameter group in and then scroll through and modify the contents of that group.
To accomplish this I have set up a directory structure that emulates a 2d array. I increment integers for each dimension with buttons that I then assemble in a string then filter through the FindTagIndex and GetIntTag functions. This works beautifully if there is data present in the tag, but when the tags are mapped to the PLC I get default values of 0's.
The problem lies in how crimson updates tag data. If I put a data display or call in a program for the tag data I want to display on the same page, the data in the list box populates and works as intended. I am trying to avoid having to call each and every tag in the background.
I have tried this with C3 build 483 and 619. With the L5k driver v2.0 and v1.4
I have discovered a work around.
By setting a change in value trigger on the tags that I have mapped to the PLC the tags will constantly update instead of waiting for a direct reference from a primitive on that page.
Jeremy,
Could we get an option to force update a tag at x interval so that we can keep the comm traffic down? This would fit nicely on the format or data tabs of the tag properties.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
251
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
108
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
97
Has anyone setup communications with Red Lion 3.0 MODBUS to Baker Hughes Centrilift GCS VFD? Thanks
92
