Crimson 3
MikeNorth
Aug 2011
Bath
Hi guys I have just bought a Redlion DSPX000 and downloaded Crimson 3 (Latest version Build 477) my problem is when I try to download my application to the DSP I get the error message "The target device is not compatible with this file" I have tried downloading a similar application using Crimson 2 and it works.
Am I doing something stupid?
I have ran into this before. Make sure when you set up your New Project you selected the correct Data Station. If you look at the top left corner of your screen it will show what type of device you are currently working on.
You should see filename-DSPSX_Crimson 3.0
Thanks Clay B for your reply it turns out I did not have the correct device selected when I launched Crimson 3 after installation it did not ask me to select a device
No problem. I got bit by that one myself. Took me a good while to figure out what was wrong. It is one you never forget...lol
When writing a User Defined action with Complex Code, can I call for a GoToPage "Popup"? I have a machine function that I want to confirm only...
16
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
158
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
315
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
138
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
125
