Crimson - Run programs without the HMI hardware ?
passwordg
Aug 2011
South Carolina
224
Hello, quick question about the Crimson HMI from Red Lion.
I'm trying to learn the software and installing the Crimson 3.0 programming software and write a program that will talk to a controllogix plc.
Can we run a project like on a windows pc or do we need their hmi panels to do so ?
Would this work on a virtual PC like windows xp running in Vmware ?
Yes, most features are available in the emulator (with some exeptions, such as compact flash operations). I'm assuming you are using Ethernet to talk to the PLC. Under the Link Menu > Options. Check the box for send to emulator, and push configure. Then select your ethernet port to use. Set up the ethernet adaptor to use, and then configure the ethernet port in windows.
You will be time limited, after which the emulator will need to be restarted. Not sure how long this is, as I have never ran into it in testing.
I was having a problem with ethernet communications to Acromag I/O once. They where able to duplicate the problem using the emulator, and my program. Was very handy.
Note: if you are using the serial port, use your normal PLC cable. (Red lion uses different pins for serial/485)
Hello all, Kinda new to Crimson 3.0. Looking to run a program when a string tag data value has changed. I haven't seen any setting to do that...
6,807
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
149
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
298
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
128
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
109
