Crimson TAG Import
einnh
Mar 2014
New England
275
I have a rather large amount of tags to import into my Red Lion Graphite project (Crimson).
I created 2-3 of these tags and exported them to a CSV so I could get the format down. I then did all my work in the CSV file for the 200+ other tags that follow the same format and re-imported. All the tags generate in Crimson but they are all error-ed out and the path say 'WAS'.
Any ideas? I'm pretty certain the format is right.
I just noticed that even if I export a tag listing from Crimson, then re-import. The source changes to 'was'
A Tag name isn't just the name it is also the path to the folder it was stored in. So warn002 isn't just warn002, it is alerts.warm002, in your editing you have changed the paths to the tags so Crimson no longer knows what they mean, that is why you get WAS.
I have a programming issue I am trying to work on in Crimson 3.0. I want to know if it is possible to import text from a file(xls, csv, txt, etc.)...
2,367
Working on a multi-state tag with 527 states. I wanted to edit these external to Crimson, so I made a few manually then exported to the unicode...
4,417
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
262
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
173
Action On Release command Set(ConveyorPopup,ConveyorPop_1) rejected w/ string tags. SetStringTag(index, data) wants an index. How does one pass...
966
