curious to know about sercos interface module
Saudi jamal
Jun 2015
oman
147
Hi guys,
i would like to know about sercos interface module.i have been study about through internet but my doubts not clear.now i want to know if this module fail i have to configure it or replace it with out any configuration.please clear my doubt.
kind regards.
jamal.
The configuration like any module is stored in the PLC memory....Once configured, it will read the configuration if you replace the module. However, the sercos modules often come like the processors, without the firmware installed. So you might at the least have to use ControlFlash to reload the firmware for the same version you have configured.
Hi robertmee,
Thanks for your reply. I understand that when I replace
Sercos module then I should reload the firmware via control flash and firmware version should be as module mentioned version.as same label printing version.
Kindly make it more clear.
Appreciated for valuable time.
Kind regards.
Jamal.
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
204
I'm focusing on Rockwell programming for a couple of projects, and I've been thinking about some of the details I've come across while working...
2,372
Hello all. I was starting to get into a new project (that will probably never see the light of day because $$$) at the plant I work in and...
26
5,623
Just curious, Have you noticed how the Honeywell C200 and the A-B Controllogix look alike? Are this two related somehow? Are they compatible...
2,047
Studio v31 FTV v10.01 Found the logic was acting backwards. so I switch the name plates on the three way "Control Mode" Right is the FactoryTalk...
1,536
