Current Driver for Small DC motor
rwatson
Aug 2017
27
Hi!
I currently have a setup where I have a brushless DC motor that I use to provide a variable amount of resistance/tension to a part which is moved by hand. At the moment, I have an amplifier board that I made myself from discrete electronic components which basically takes a -10 to 10V analog input and outputs -3.5A to 3.5A into the motor. This does the job and I have never had any problems with it, but it would be good to know if there was an industrially hardened product out there that is DIN rail mountable and does the same thing.
I have seen some DC motor servo drives that can be used in torque mode, which would probably work, but I don't want to spend money on a servo that has position control/torque control etc, when all I really want to do is put out a linear -3.5A to 3.5A. It doesn't even need to have particularly good resolution or accuracy as the torque felt by the operator is pretty subjective.
I probably should have mentioned that my supply voltage is 24V. The stuff on sparkfun would probably be alright, but my main concern with what I'm using at the moment is that it doesn't really look like it belongs in an industrial control panel.
Hello all. I have 200 kW ATV38 driver and this driver runs a 160 kW motor. It is a fan application. Problem is : There are big current...
1,208
I'm looking for a somewhat specialized driver card for a proportional valve. The card needs to be able to output a current to a single solenoid...
3,418
Hello to all, can you please provide an example of obtaining a current working directory as a string in CodeSys? For example, during starting the...
232
Today I was working on my project for school and we were using a power supply with 24V and we accidentally had the current at 0.9A. We heard a pop...
588
Hi all, I have been working on a project that requires me to measure the current across a 90 VDC motor of a medical device (similar to an...
26
1,747
