Cx programmer PRV instruction in ST
andepand
Jan 2017
Amsterdam
72
I checked the forum, and actually the rest of the internet also, but I can’t find an answer to the following.
I’m programming an Omron CJ2M with an MD212 high speed I/O card. I usually do all my programming in Structured text, simply because I like it a lot over ladder or sft.
Now, if I want to read the hight speed counter (incremental encoder), I have to make a ladder section and use the PRV instruction to store the present value in a chosen location.
The manual says the current PV is stored in A271, but I can’t get a readout there. Apparently the only way to read it is through this instruction.
Does anyone know if there is an equivalent to the PRV instruction for Structured text? or another way perhaps? Again, when I check the actual memory adress, there’s no value there withouth the use of the PRV instr.
bonjour je souhaiterais savoir si c'est possible de faire communiquer Cx-programmer ( logiciel de programmation des automates Omron ) avec...
167
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
167
I need a good website or tutorial to learn plc programming Thank you
520
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
394
Dear all, First of all thanks for letting me join this forum. I just need some help in one of my programming exercises. Being a beginner...
624
