D9 to D9 connection cable for CP5512
lagos
Feb 2008
Lagos
I need to make up a connection cable to connect my CP5512 adaptor to a S7 - 300 CPU 315- 2DP programable controller.Both the CP5512 and controller have female D9's.
What is the pin configuration for the connecting cable?
For 187.5k, just buy a normal straight DB9 to DB9 cable.
If it has to be used for 1.5M or 12M, then get the original Siemens cable 6ES7901-0BF00-0AA0, or use Profibus connectors and cable.
MPI CABLE 187.5 KBD MAX 6ES7901-0BF00-0AA0
I have maded from 3 m Null-modem cable with female DB9
Or you can use standard 2-wires Profibus cable and connect pins 3 and 8 and screen.
You can use female DB9 socket or Profibus socket (with/without terminator resistors)
s7-cpu314 cable
Deras.. is that cable connection is suitable to connect plc s7-300 cpu314 with pc for programming? waiting for reply
Maybe. It will work in conjunction with a CP5512, CP5611, CP5621 or similar. It will not work by merely connection the serial port of the PC with the MPI port of the 314 CPU.
Anyone knows how to go from the CP5512 DB9 straight to the 2-wire profibus network? I'd like to use the MCT10 software from Danfoss to connect to the Profibus network and upload all the drive's parameters but there's a lack in the documentation on how to go from the CP5512 to the 2-wire profibus.
The CP5512 can be configured to work with Profibus.
Go to "Set PG/PC interface" and select CP5512[PROFIBUS]. Press the properties button to setup PG/PC address and network speed.
Goodluck!
Goodluck!
I know it can, but I don't know how to connect physically to it. Not on the PLC port, directly on the 2-wire cable that daisy chains from one device to another.
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
253
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
235
Hello everyone. I want to connect to CU240S DP CONTROL UNIT 6SL3244-0BA20-1PA0 Siemens brand driver we have. I am using starter software. Our...
513
Hello, I have a recordable horn I am trying to drop some .mp3 files into. Part no. 856T-BH3. It requires at a USB A 2.0 to Micro USB. I have used...
2,064
Hi, expert: we have one machine with 6 Sercos axis (kinetix6000) controlled by L71, there are 1756-M08SE and 1756-EN2T and one input module and...
2,673
