Dancer Positoners
scottmurphy
Oct 2004
363
Can anyone recommend a linear positioning device for a Dancer arm?
Have done some google searching, but haven't been able to find anything yet, are these an off the shelf item, or generally made to order?
Do a search on "Dancer" here, there are some good suggestions.
In the carpet and textile industries, I have seem more and more lasers being used to control the dancers. The lasers are the type that give a 4-20 ma feedback.
Hi Scott,
We usually use a linear transducer, mostly Balluff. Generally they are off the shelf unless you have an unusual size or output.
George
Do you want to position the dancer or measure it's position ?
If you want to measure it's position I've used a Telemec linear proximity in conjunction with a cam on the dancer. This is a Non-contact method so nothing to wear out and cheaper than an LVDT.
I'm working on an existing payoff of a wire machine. It has a motorized payoff controlled by a Control Techniques Commander SE AC Drive using a...
19
6,242
Have some equipment we built a few years ago that we utilized the micrologixs 1400 plc and allen bradley powerflex 525 drives in. Will refer to...
3,263
anyone have a idea on who makes a laser type analog output sensor that could be used to detect the position of fabric and trim a AC drive...
2,793
Hi guys, We have a customer that is using a Yaskawa MPiec Motion Controller with some remote I/O to do a bagging application. They are using a...
3,081
Hi all, I will try as best as I can to draw you the mental picture. I am winding flexible plastic film with a gauge of 60 micron and a web width...
3,443
