Danfoss FC 51 SLC Settings
kiranprama
Feb 2010
hyderabad
Dear All,
Am having an application which send analog output o-10V dc depending on its exhaust requirements.We had connected a VFD with Danfoss FC 51 Micro Drive Installed in it to a 5HP motor. till Now every thing is fine but my problem is my application will not send signal unless until the motor is on and motor will not on unless this drive gets signal. i request you people to let me know the settings of Smart Logic Contrroller(SLC).
Now i want the drive to understand the signal as menioned below
1. 0 Volt means Motor Off
2. 0.1 to 1 Volt means Motor Starts at Full Speed intially for 2-3 Minutes and accepts signal after that
3. 10 Volts means Motor on at full Speed
Please Let me know the details at the earliest.
Regards
Kiranprama
I am not familiar with the Drive you are using & did not find the instruciton manual for that model when I searched for it online. I believe your problem may be in the way you have set the drive parameters. We would need to know those details in order to help.
Details of FC 51 Micro Drive
Dear Tom,
thank you for at least considering to have a look at the problem i mentioned and replying it.
please fidn eblow the link to programing guide of the drive am talking about
get.club.officelive.com/Documents/FC-51%20Programming%20Guide.pdf
please try to have a look at it.
regards,
Kiran prama
Hahahaah Nice solution
Dear tom,
i too can read english n numbers sorry to say that but i have the manual but still need technical advise from the professionals. if you dont under stand the issue for gods sake please dont reply it which may cause the moderators to think that the problem is solved
any how thank you for your consideration
regards
kiranprama
am Struggling really very much
Dear Silva,
thanks for you too but am afraid i dont have that much engineering stuff above my shoulders to see the manual and find the solution by myself.I am in damn need of technical piece of advice from professionals, buddy.well i thought this form is full of professionals but my faith is going in low note because after putting my problem in forum even after three days i didn't found a single quality reply.
thank you once again for sparing ur time to reply.
regards,
Kiranprama
kiranprama
May i suggest you read read the section of the manual and contact danfoss as suggested
If you dont take free advice (some will be excellent, some wont) as it comes why bother joing a forum?
I suggest you get your head out of your rear orifice and do as you have been asked to do then come back with any results
thanks CJD for ur suggestion. actually am in contact with Danfoss india service Team but they r lil slow in their response,so am trying to find the solution in possible other ways also.
egads,
kiranprama
Hello all, I am trying to talk to two Danfoss VLT 8000's over ethernet using the Danfoss "Ethernet Master" module. Has anyone else used one of...
18
10,588
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
51
Hi all, We are currently experiencing an DC over voltage fault on one of our inverters. During commissioning a snag was raised whereby excess...
207
hey guys i've been trying to find an updated SW files of my danfoss fc360 for MCT 10 software but i couldnt be able to find it anywhere on...
258
Hello all. I am hoping someone here has installed a Danfoss VLT Midi FC 280 and connected an encoder to it. I am just trying to make sure I select...
468
