data logging in compactLogix L32E
Vaibhav Thite
Dec 2019
Aurangabad
Respected sir/madam
I have CompactLogix L32E And I want to data log into logic . is any module or card require to it.
request you guid me and if possible send me technote for this.
Regards,
Vaibhav
Your question is very vague. Are you looking to store data in a local array? Are you looking to store it on a server? Are you using a SCADA? How much data are we talking about? There's a major difference between "a few tags" and all of your sensors.
You shouldn't require a "card" on the PLC side, but you may need additional hardware to store/process the data depending on the quantity...
Hello Vaibhav Thite:
There is one expansion module for CompactLogix made by Softing that requires no PLC programming and can store values from CompactLogix tags which can be holding data from sources retrieved through any type of Rockwell I/O, whether local or remote. This card has SQL client capabilities and allows you to log data on an SQL server, and the configuration tool for this card is extremely flexible, allowing you the triggering of SQL request under different conditions. It does not come cheap though, but the cost of the card I believe is offset by the savings in engineering time. Below for your reference I copy the URL for the product. I hope this information is of value to you.
https://data-intelligence.softing.c.../rockwell-modules/eatm-tmanager-compactlogix/
Hello , I'm looking at purchasing a data logging system for compact logix controllers. Does anyone have any suggestions on what you would...
1,620
Hi, Can anyone suggest a solution to log data from remote sites around the world into the cloud. Some sort of IOT gateway perhaps? Thanks,
4,110
Hello all I want to do some data logging, which I have succeded in doing on my Rockwell CompactLogix directly onto its CF/SD-Card. I just...
2,279
Ladies & Gentlemen, I'm new to the G3 world(and this forum) and have a few questions regarding using a G315 to capture Tag data from a...
3,185
Hi all I would dearly like to log data to the CompactFlash card in a 1769-L35E CPU. Is this possible? All I can find on the AB KB is an...
5,105
