Data transfer using udt
farima
Jan 2015
toronto
I want to transfer 4 bits from AB PLC(studio 5000, logix designer) to ABB ROBOT(IRB 1600) , the type of data is DINT and send the data when camera sees the part. can I use UDT? If I can, would you be kind enough to tell me how to use it? many thanks
Try using the BTD instruction. You can parse out the 4 bits from the DINT you want to send. As far as the actual transfer to the robot, I can't help you there. No AB robot experience here.
Hello all. Would anyone have sample code that uses a wall clock to move the CTU.ACC to a another variable in the PLC after 24-hours has elapsed? I...
1,938
is it possible to transfer input and output data from one cpu to another in s7 200 using profibus for program lader logic
1,272
Hi. We have mashine with AB SLC5/04CPU PLC and Proface AGP3500. I need transfer data AB SLC5/04CPU PLC to TSX momentum PLC using ethernet...
6,354
I made a previous thread about s7-300 communications in reference to choosing and setting up the right hardware. I decided to go with the DP/DP...
2,678
Hello Everyone, I am using a raC_Opr_NetModbusTCPClient AOI module, as below,. So, I need some assistance to restrict in reducing the poling...
82
