Data Transfer
jm barboza
Sep 2005
Monterrey
Actually I have in operation a PCL 5/15 in a old section of my process, a new project added a new process; this new process is using a SLC 500, and I need to connect some old signal to the new one. I have the DH+ option in the old one, the question is, Can I transfer data from the old one to the new one using the DH+ port, what type of interface or software I need to complete the job ? The types of signal to transfer from PLC to PLC are 4 analog inputs (4 to 20 mA) for calculation proposals
I will appreciate your help
Right, is the SLC 5/04.
that's good news ...
yes, you can transfer the data ... you shouldn't need anything except a piece of "blue hose" cable (and the connectors and terminating resistors) to connect the two processors' DH+ ports together ... then program an MSG (Message) instruction in either one of the processors (your choice) to either READ the information FROM the other - or WRITE the information TO the other ... you won't need an MSG in both processors - just one or the other ...
let us know if you need more help with the details ... once the cabling is done, the programming should take less than an hour (if you're new at it) - or less than five minutes (if you're experienced with such things) ...
good luck ...
Hello Everyone, I am using a raC_Opr_NetModbusTCPClient AOI module, as below,. So, I need some assistance to restrict in reducing the poling...
34
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
122
Hi all, I am working on a project that with need to capture force sensor data in footplates in order to determine if weight shift is occurring...
532
Has anyone here successfully created a system where the software SAP (ERP) interfaced with an Allen-Bradley PLC? Currently we have to take recipes...
1,132
Is there a way to move a tag value, brought into the panelview via modbus tcp with kepware, back to the plc on eth/ip. IE on the C-Mores we bring...
433
