Database Import Export
gbradley
Apr 2002
Corona, Ca.
1,637
This may be stating the obvious.
I had an issue earlier today.
My boss downloaded a file from the PLC (SLC500)where he had made some rung changes.(don't worry he is capable)
Since the ladder file was uploaded from the PLC, there were no comments.
I did have a previous version of the file that had the comments.
I was able to use the Database ASCII Export/Import to Export those comments to a file.
Actually 5 separate files.
Then Import the Comments and descriptions to the file that was missing them.
Worked like a charm.
That was actually more work than was really needed. All that really needed to be done was to upload the file from the CPU and merge that with your existing offline file. Then you would have had your program (and comments) along with the changes made to the CPU. When done, use the Save As option to give it a new name if you wish.
The Import/Export is really only necessary if you want to merge two different databases or work on documentation in another program like Excel.
OG
Operaghost:
Where is the merge database option offered within RSLogix? I can remember seeing it before, but can't find it now.
I, too, have been doing database merges the hard way apparently.
Thanks,
Paul
I have an old Starter version of RSLogix, so I don't know if I can merge documents. Compare is Grayed out.
Anyhow, the Hard way seemed pretty easy to me.(y)
That's why I thought I'd share.
When you try to go online with a processor and don't have the matching file you have the option to browse for the file you want to use and then you select "Upload and Merge with existing Database"
Hi, When I export the csv file, display it in excel or notepad and then add some new tags that I've copied from current tags but changed the...
3,228
I know how to do a database import and expoert in Rs Logix 5 and RS Logix 500 just to get the comments but I am trying to figure out how to do it...
4,878
Hi friends, I am working on fix32 with CLX processor first time. As rslogix supports csv format for tag edit, I want to import tags from CSV file...
6,479
I am trying to import addresses and symbols from a PanelBuilder32 application into the RSLogix 5 Address/Symbol database - however each time I...
539
Hi, I am having troubles importing a 500 internal database for tags on FTV ME i am getting invalid tag name Cause: Illegal character ('') at...
1,134
