Date and time not working. (Help)
Avatar_41
Aug 2019
Istanbul
96
Hello guys, I want to use the project in the link. (https://support.industry.siemens.com/cs/document/*1***0*6/how-can-you-read-out-the-date-and-time-with-sfc1-(read_clk)-and-set-them -with-sfc0-(set_clk)-?dti=0&lc=en-WW).
The time and date reading part of the project works, so I can see the values, but when I want to change the time, it does not respond. I am sharing my project below, can you help me please? Good work.
You need to understand how to use function blocks and their instance data. When you call an FB, the value of the input is copied to the instance DB - so it does not make sense to use the instance data itself as the passed parameter - similarly for the output data.
The reason your date setting does not work is because the edge detection storage bit is declared as an input - it needs to be a STAT.
Hello All, I am facing a wierd problem on S7-400 PLC. I am trying to extract date using following simple logic & using PLCSIM to test it. SFC1...
2,871
So we have a few associates that like to write the date in the file name when saving the program to back it up. We back up the programs every...
135
Hello Everyone, I want to upgrade the firmware of Powerflex 40 from 5.001 to 6.002 can anyone tell me how can I do that?
73
136
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
312
