Date Difference
JkellyNPFD
Dec 2007
New York
I'm using a compactlogix PLC and RSLogix5000 software. My question is this. Is there a quick and easy way to get the difference between two date/times? Basically i want the difference in seconds between the time the PLC lost power, to the time it is restored. I want to compare that number to a user-defined maximum time.
Thanks,
John
Nevermind, I figured it out. I'm going to use the 'CurrentValue' attribute of the WALLCLOCK object. This gives the current time in Milliseconds starting from 0000hours January 1, 1970. Now i can use a sinple compare of the two numbers.
Hello, I'm hoping someone can help me with understanding how to set/change these data types. We recently swapped from Invertek to AB drives...
102
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
298
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
128
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
109
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
143
