DB-9 serial port testing on ML-1400
dharmaraj12
Mar 2013
mumbai
hello friends
i have an old ML-1400 which i purchased from a ship owner which was used in that ship
now i wanted to test the serial port(DB-9) of this PLC
as far as normal serial port which are on PC i know that shorting pin 2&3 and i will get same responce back on my PC hyperterminal which i was typing
but how to check PLC db-9 COM PORT i dont know
can anybody tell me how to check it??
waiting for your replies
Have you tried to communicate with it using RSLinx?
A null-modem cable.
thanks mickey
just tried it with with null modem cable and it worked
it means my commport is o.k
thanks for your suggestions:site:
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
162
I have lm9030 program on my toughbook CF-29 cannot get my program to hook up with the serial port.
76
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
719
i have a dell laptop with a real com port host OS is windows 10. Running VB 6.1.42 I cannot get the serial port to configure in VB. Please Help...
1,045
Hi All, I have set up a Moxa NPort serial server for an application. Unfortunately the environment requires NAT forwarding between 2 systems...
836
