DB backup Online Value Siemens S7-400
Daynada
Nov 2005
Wisconsin
28
How do I back up my DB's that are on the PLC? These are values that are constantly changing and differ from the initial entries. Oh and there is thousands of entries in a hundred or so DB's. I want a back-up copy of actual values on my laptop. I also want to be able to easily load them back into the PLC if I wanted to go back to settings from a few days ago (or if I lost the PLC memory or something.)
Thanks.
I would make a backup copy of your off-line datablocks before doing an upload. If any of the on-line datablocks differ from the off-line datablocks then you will lose any comments in the off-line datablocks when you upload the on-line block
Good point! Sometimes I add a new S7 Program to the project (Insert > Program >S7 Program) Rename it with the date and then upload my online db's there.
I want to make sure that this will grab the values that are in the PLC. The values in the PLC are different than the values in the offline DB. Does this feature move the PLC values into the initial values of the DB? Other than the current values the DB's are exactly the same.
Thanks!
"Upload to PG" versus "drag and drop"
How does "upload to PG" differ from connecting to the online program and draging the DB's I want into a new S7 off-line folder?
I use two other methods to "backup DB's".
1. As a maintenance function I upload the entire project to an empty Step7 project and then download all that projects blocks including system data to a Flash Memory Card.
2. For operator use I use Citect SCADA to maintain a database of "Job Information" records that include PID control setpoints, alarm limits etc. The operator can manage these records, saving a record when everything is running well for later use when the same job runs again.
i'm programming an omron CP1H with cx-programmer - does anyone know if "memory backup" can be suppressed when sending online changes?
1,589
hi All Can you please help me to find the right software to open Zip backup of 434 12A PLC? Any major steps I need to know when opening? Regards
90
Is there a way to reset the count on the RS Logix BackUp?? XXXXX PROGRAM IN PROGRESS_BAK445.RSS XXXXX PROGRAM IN PROGRESS_BAK446.RSS XXXXX...
267
Please help me How to B&R 7CP476.60-1 upload program Backup and download which program should I use. Pvi transfer tool.? And how. Thank you
109
Hello all, I have an ABB PLC (PM573) and it has without MC card. I need to take backup from PLC to PC (in automation builder v2.7 ). My...
477
