DB indirect addressing with parameters
jormaga
Sep 2010
Madrid
Hi everybody!
I'm trying to do quite a simple thing (I think) but I'm stucked and don't know how to implement it...
I call FC6 (DT to DATE) and the RET_VAL parameter I want to use is located at a DBW in a DB with no fixed DB number.
I tried the following code but I got an error, could anybody enlight me and tell how to fix it?
AUF DB [#iDBPlc] // iDBPlc declared as local int
CALL FC 6
IN := #dtDATETIMEPLC // dtDATETIMEPLC declared as local date and time
RET_VAL := DBW30
The date variable was declared at DB2.DBW30 when I ran the code but got an error. When I use RET_VAL := DB2.DBW30 don't get any errors, but it's not flexible the DB number addressing.
Thank you all!
Regards,
Jorge
Use a temp variable of type date as the return value from FC6 and then copy the temp variable to DBW30
possible solution
I realized that I could do the following:
CALL FC 6
RET_VAL := #dDATEPLC // dDATEPLC declared as local date
L #dDATEPLC
T DBW 30
And this really works. I just wondering if there was another way to do it directly without declaring an extra local variable 'dDATEPLC'.
Howdy folks, I am an Allen Bradley guy currently living in an Emerson world. Working with Rx3i on PacSystems Machine Edition v. 9.6? i think...
624
Hello, I'm very new to programming with absolutely zero schooling in this field and pretty hands off training in my new role, it's been fun...
670
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,387
Hi All, which the best way to do the indirect addressing in an optimize DB? Ccurrently this is my partial code inside an FB...
2,278
Hey everyone, Just used the PLC5/Logix migration utility to convert a program, and while addressing the PCEs, I noticed a lot of errors for "XIC...
1,989
