dc motor+drive / ac motor+drive power saving
Kataeb
Jan 2007
www.livelovelebanon.com
636
Hy guys, between a dc motor+drive and an ac motor+drive, which one has better power factor? Which has more energy savings? Has anyone approximate figures that show the power consumption difference between the two. Thank you
Well, as usual, it depends. In North America, using a modern Premium Efficiency AC motor, you can expect about 7% better efficiency with AC.
Exactly how that translates to Lebanon, I don't know, but you should expect at least 5% better efficiency with the AC system.
Don't forget the huge difference in motor maintenance costs over the years.
I think on the drive end as well, between cables losses and losses in the electronics, DC drives tend to have more waste heat. I am not 100% certain of this, but it is something I have noticed.
Good morning, I'm searching for a power supply to convert 3 phase 480VAC to 120VAC and 24vdc. Is there an all-in-one power supply like this on the...
113
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
75
359
Looking at installing point io, with a 1734-AENTR communications adapter and ten 1734-IT2L modules. In IAB it installs a 1734-EP24DC after every...
97
First time I've used either the software or this unit. This is the setup I have right now. I have 20mA coming into AnalogIP1. Both the Main.PV...
62
