DC Motor replacement using AC Motor
JamesWSY
Jul 2005
Jakarta
81
Hi..
I have cut to length machine with 40 meter/min speed using 7.5 HP DC motor and analog drive. I want to replace the DC motor using 10 HP AC motor c/w encoder as speed feedback and using Powerflex 700 and compactLogix processor. The tolerance is 2 mm. Any idea or suggestion?
Thank you.
James
Hi : A customer have a servo motor MPM 3203R-1170, this motor was driven by a MPA-75-460, both unit were manufactured by MTS. Parker Hannifin...
3,637
Application: Lathe Present motor: 220V, 60kW, 3000 rpm driven by 6RA70 SIEMENS DC-DC Converter. Mode: Armature speed control with constant shunt...
2,937
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
224
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
309
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
162
