DDE/OLP to trigger Excel
DannyD303
Nov 2016
Hingham, MA
30
Hello all,
I watched the tutorials on how to bring data into an excel file using the DDE/OLP function. What I'm trying to figure out is how to use a BOOL control tag to trigger a macro inside of an excel sheet, if possible.
The details:
The machine in question has an input the operators can use to pause the operation of the machine for a variety of reasons. What I am trying to do is record when and for how long the machine is paused and for every time the machine is pause to have the excel sheet increment a cell by 1.
For example:
2/27/2017 12:55 30seconds
2/27/2017 13:15 10 seconds
I found a way that I can use a timer inside the PLC to capture how long the switch is active but it wont tell me if it was paused for 10 seconds 6 times, or if it was one time for a minute.
Any help would be appreciated.
Thank you.
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
91
Hey Friends. I am currently trying to write approximately 700 tags from FtView13 to an Logix Emulate 5000. I am using rslinx DDE/OPC to create an...
400
I am upgrading an old RSView32 v7.60 HMI to FactoryTalk View SE version 12.0 and I have an issue. There are some excel reports generated daily...
1,014
This used to be an easy task in the past to get data into Excel, now I have 365, Excel just hangs when I paste the link. I've seen some guides to...
1,249
Hi, I'm brand new to the forum and spent some time looking around but could not find an answer to my question. I'm using an excel spreadsheet to...
1,341
