DDE Poke Excel to PLC
xC0MMAND0x
Jul 2013
Minnesota
265
I know there are other topics on this, but I'm trying to get an already working Macro in Excel to run on my machine (Win 7 64-Bit). I'm thinking there might be a problem with the 64 bit system, as it works okay on other 32bit systems.
Here is the code, as well as 2 screenshots of the errors. It is having problems with RSLinx.
Code:
Private Sub CommandButton1_Click()
'open dde link:
Dim RSIchan As Long
RSIchan = DDEInitiate("RSLinx", "Test_Pin_Push_App")
'write data thru channel
DDEPoke RSIchan, "TagValue", Range("A1")
'close dde channel
DDETerminate (RSIchan)
End Sub
And here are the 2 errors:
I have tried explicitly adding the following code, but it didn't work either.
Code:
Dim RSLinx as String
RsLinx = "C:\Program Files (x86)\Rockwell Software\RSLinx\RSLINX.EXE"
Any thoughts/ideas? Is it a 64-bit OS issue?
Your code worked on my W7x64 machine. The first time I ran it though, I hadn't created the DDE topic Test_Pin_Push_App in RSLinx and I got errors similar to yours.
o_Oo_Oo_O I had my topic name wrong! I had Test_App_Pin_Push.
Thank you for testing that and pointing our my careless mistake! I'll reconfigure and test it when I have time.
I know this has been covered many times and I have tried EVERY code snip-it that I have found to no avail... First off I have data already setup...
22,051
Hello all, first time posting here. I am writing a VBA routine to write tag values in Logix Designer 5000 V30 using DDE poke. The tags in want to...
1,651
Hi. I am having trouble writing to an address in Control Logix using Visual Basic if it is inside a UDT tag. For example if I create a new tag...
2,647
Hi , I've managed to get a DDEpoke comand set up to send the string data from cell A1 in an Excel sheet to ST15:0 in a Micro logix via RSLinx...
8,511
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
99
