Delete Items from Symbol Table in S7 ?
GTX
Dec 2003
36
Hi
This might be a dumb question but i am going to ask anyway.
Right now I am trying to delete some unused entries from my Symbol Table in a S7 program I am working on and not matter what I do I cannot delete them.
Any ideas how I delete them ?
Is there a way delete and entire table and start a new one ?
Thanks for any help :)
Hello
Try opening the symbol table from the main tool bar. Right clicking on the option you want to delete will give you a drop down menu.
Hope this helps.
Fiona.
What exactly are the symptoms?
Normally I would expect you should be able to grab multiple rows by just clicking and dragging down the column with the numbers in it, and then right-click and delete.
Depending on the version of STEP7 you have I believe there was sometimes an issue if you suppressed the warning message that is offered when deleting (the dialogue had a check-box labelled 'Do not display this message again'). According to the installation, o/s, etc etc, sometimes this resulted in an inability to delete anything after that. If you've done this, go to Options / Customize on the main SIMATIC Manager menu, and under the General tab, click on the button to 'Activate' deactivated system messages. This should do it.
Good luck and regards
Ken
GTX, is there any chance that the ones you are trying to delete have a pink background? If so, I had the same problem a few months ago, and I think my symbol file became corrupt somehow. No matter what I did, I couldn't delete or rename a certain symbol. The symbol was "VAT4", and I couldn't create any new VAT Table symbols without getting rid of the corrupt symbol.
Finally, I exported the symbol table, opened the exported symbol file in WordPad and deleted the symbol, deleted the orginal symbol file in S7, added a new blank one in S7, and then imported my edited symbol file. Life has been good ever since.
Ken
Ooops!
How did that get there?
Finger-trouble somewhere on my desk-top I guess.
Sorry.
Ken.
Thanks guys !!
I ended up deleting the symbol table from the SIMATIC Manager program.
Hello, someone have experience about how to delete an alarm message(alarm already solved) from alarm viewer with something coming from PLC? THANKS
847
393
In my project, I've set up a few user accounts (Operator, Technician, Admin). The person assigned as Admin has said "I want to be able to...
1,174
In the Communications > Network > Protocol 1 - AB Tag Names > PLC10 configuration page there is a Tag Names section (not the same as the separate...
2,502
Hi , How can I remove this tag without affect the instruction, i mean is only a tag with 0-1 value and I want that my instruction has only ins...
1,632
