Delete .mer file from panelview plus
Jun 2006
Tennessee
I have two .mer files on a panelview plus
One of them won't load because it is the wrong version
I would like to delete this one from the panelview
How would I go about this
If you can access the configuration screen from your PanelView, navigate the menu to the "File Management" option. (I believe this is correct, I don't have a panel sitting in front of me.) From there, you will be able to delete files from the PanelView Plus memory.
If you *do not* have access to the configuration screen (which is not the best practice, BTW), create a new application with one screen. On that screen, put a "Go to Config screen" button on it. Then you will be able to delete not only the new application you just created, but the other one you wanted to git rid of as well.
Rick
Further to Rick's post Rockwell app. note A55863468 has an application to enable you to access the Configuration Screen even if you're running an application without the necessary on-screen buttons.
Rick
This is right I just performed this task as he said and it solved my problem.
Hello, someone have experience about how to delete an alarm message(alarm already solved) from alarm viewer with something coming from PLC? THANKS
840
387
In my project, I've set up a few user accounts (Operator, Technician, Admin). The person assigned as Admin has said "I want to be able to...
1,156
In the Communications > Network > Protocol 1 - AB Tag Names > PLC10 configuration page there is a Tag Names section (not the same as the separate...
2,487
Hi , How can I remove this tag without affect the instruction, i mean is only a tag with 0-1 value and I want that my instruction has only ins...
1,624
