Design Ideas
Tim Ganz
Dec 2010
Dallas, Texas
694
I have a grinder that we are going to put new controls on. The blade motor is 480 and the hydraulic motor that opens the blade chamber is 120 volts.
The motor starter for the blade motor needs to have power isolated from it before the hydraulic opening circuit will work.
This is will all be from the same panel and one main 480 disconnect and a 480 x 120 transformer.
I could but a breaker before the motor starter for the blade motor but that would mean opening the cabinet to isolate it which I would like to avoid.
blade motor is 40 hp. Fitting dual safety contactors above the blade motor starter would chew up all the panel space at that size.
Any ideas?
Use normally close contacts from the blade starter breaking the feed to the hydraulic open circuit. Use a limit switch breaking the control power the blade starter if the door is open. Allowing the start if closed.
How about a cable operated disconnect to your blade motor circuit breaker. You could lock it out without opening cabinet. We use these on our regrinders for plastic, lock out the grinder and still able to use the actuator to open up for cleaning and blade changes. Once the unit is opened we then lock out the control side also.
I had a simular problem, differant equipment. I bought some 6 pole disconect switches.
600V rated we were using 480 v 3 ph. worked very well.
I've got a new project coming up involving these two platforms. Unfortunately, I'm not really a PLC programmer, and consequently I have about 5...
4,126
Hey everyone, I am a senior in an Electrical Engineering program. We are looking for a good project to do using PLC's. I have worked with both...
2,542
I am working on a complex process cell or what to call it.. It works like a line with a continuos flow where you fill molds with product and it...
4,772
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
159
I've run into a non-plc issue that is proving hard to solve. I'm designing a mechanical device that has a base/foundation that must satisfy the...
406
