DeviceNet DasiyChain Resistors
Jmeadows7676
Oct 2013
Alabama
158
Hello guys,
Does anyone know if you have to have terminating Resistors at the begining and at the end of a (DasiyChain) DeviceNet Network? I know when using a Trunk Drop Line type you have too, but not sure about DasiyChain.
Yes, 120 ohm resistor at both end-of-line devices on the daisy-chained network. If extending from an existing EOL device, you would move it to the new EOL device.
p.s. forgot to add...some devices have the termination resistance built in, or switchable, just to bear that in mind.
Regards,
George
Hi. We've been asked to do an upgrade on plant, consisting on a PLC upgrade. This involves replacing a 1747-SDN module to a 1769-SDN, in a network...
64
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
174
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
144
We've run into an old system that we are upgrading which is still running Steeplechase with Citect using Devicenet to Wago. I had some experience...
165
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
152
