DeviceNet Power Supply
Oceansoul
Apr 2010
England
307
I am adding a new DeviceNet network to an existing controllogix L71 system, but i'm having a problem with the power supply for the DeviceNet bus power.
The controls cabinet has twin 110VAC UPS backed feeds (via fused switches) which then feed into a dual input 30A 24VDC PSU. Everything else in the panel is 24VDC. There are spare ways in the 24VDC distribution, but i am reading that a standalone PSU should be used for the DeviceNet bus power.
Is there an allen bradley DeviceNet PSU that has redundant 110VAC input? OR would it be okay to use two 1606-XLDNET8 and parallel the outputs (or use a diode block like http://uk.rs-online.com/web/p/power-supply-accessories/7397890/).
Unfortunately there is so little AC in this panel and i cant find DC-DC DeviceNet PSU.
Haven't done a redundant DNet Power Supply, however on page 4 of the 1606-XLSDNET manual:
"(1) Power supplies can be paralleled to
increase output power or to build redundant
systems."
Thanks for the link, i guess that was the manual i needed to read. Looks like im good to go. Just need to order a second PSU now.
Is there anything really special about Allen-Bradley's 24VDC Power Supplies for Devicenet?
3,232
Hi I am trying to setup a DeviceNet network with 3 CN2DN and each CN2DN connects to 12 or 13 Schneider TeSys devices. My question is that I am...
4,794
I am trying to select a new power supply for a small devicenet network 10 nodes and it currently has a standard open frame power supply and we are...
9,085
Good day Forum Members I got a older Lincoln welder and hoping to make it work at our shop. Welder in question is the Lincoln Power Wave 455M...
223
We have a devicenet consisting of 15 PF755 drives in a centerline MCC, and on a separate trunk cable coming off the scanner, a single PF525 in a...
352
