DH + Question
kbradray
Jan 2006
Columbia
175
I have a SLC 5/04 and I want to put it on a DH+ network. I am using a controllogix bridge to get from my business network IP subnet to my plant floor IP subnet and a DHRIO card. The DHRIO card is set up on Channel A communicating with a PLC 5. I want to use Channel B to start a new DH+ network.
Question 1. The node address for the SLC 5/04 is 1… What is the node address of Channel B? Will there be any conflicts?
Question 2. What is the default node address of SLC processors and older PLC 5 processors.
Question 3. Can a node address of a PLC on a DH+ network be changed by navigating to the processor via the network, or does one have to plug directly into the processor (in my case) via DH 485
At this time I would like to leave the node address of the SLC because it is in full production and I don’t want to take it in to program mode (down) to make changes at this time. I was hoping to put it on the network with out any downtime.
Thanks in advance for assistance.
You may have different processors with identical node addresses as long as they are on separate channels.
Question 2. What is the default node address of SLC processors and older PLC 5 processors. Default is always node 1
You may change it via the network.
BAKLAVA!
But, really, there's no reason that the SLC cannot live on the same network as the PLC5. You just need to make sure that everything is wired properly and that all addresses are unique on the network.
Thanks all
I did just put it on channel a along with the PLC 5. Everything is happy and on line. I will change the node address whenever the machine is down and I will not bother production.
Thanks again.
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
173
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
73
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
93
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
95
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
