No its the same, the only setting on the DHRIO is address and DH+ or RIO... you can leave the gateway as default unless you need to use it
Either way as long as you are plugged in the DH+ network then will show up in your Ethernet
what do you put for controller slot # in channel configuration for dhrio module
