DH485 to Ethernet network?
bentleya
Nov 2002
NE KY
69
Hi all,
I have several SLC 5/03's and 1200 micrologix networked with DH485.
What I am wanting to do is tie this system in with our plant network (10/100baseT ethernet).
Should I change the 5/03's and go with 5/04 or 5/05 to get the port on the PLC or is there a good way to access the DH485 network where I can address all the PLC's on the network?
This would be for accessing data only.
Any thoughts appreciated!
One of our customers has achieved this by using the 1761-NET-ENI module. They simply convert the DH485 to ethernet, though you will only talk to the processor at 19200. The other option is to upgrade to 5/05 which is pretty costly as well.
Rob
Hi, I want to know if and how i can bring up my DH485 network to a ethernet/ip. My network is setting with 1747-aic and 1761-net-aic. So i...
2,305
Hi Everyone I have an existing DH485 network with around 7 nodes I wish to have access to from our ethernet network..The highest spec cpu is a...
18
14,895
Hey all, long time reader but first time poster here. I've been tasked with an odd one and was wondering if anyone else had experience in this...
17
5,360
Hi, I have PanelViev 1000 grayscale and SLC5/03. I run SCADA via ethernet bridge that is connected to SLC5/03 via RS232. The PanelView is...
4,455
Hello Friends I need to communicate a 5/04 with a Micrologix 1400 to send and receive some bits and integers, also I need to connect ML1400 to...
3,116
