We mainly use two tools to troubleshoot Profibus networks:
1. Fluke 125s oscilloscope
2. Procentec's profitrace analyses.
With these tools we be never been defeated. Especially with the second tool.
You could use a simple scope but the issue would be the trigger of the scope.
All you would see would be square pulses moving around the screen.
What makes profitrace special is that it's DSO can trigger on the messages, so that you can see the quality of the pulses for each slave.
The scope is only one from a series of features it has.
The Fluke 125s is not a protocol analyzer but a bus health monitor. It knows the characteristics that a Profibus pulse should have and it will tell you if that is within the nominal ranges.
The greate thing about the 125s is that you can use it for Profibus, mod bus, Canopen, device net, RS485. You can even setup a custom protocol if you know it's properties. The 125s can also operate as a sumple 40Mhz scope, as a harmonics analyzer and as attend recorder.
I highly recommend both tools.
Regards Nik
