Difference between I/O modules and protocol
elmer_w
Sep 2020
Brisbane
Is there any difference between I/O modules (discrete and analog) and communication protocol (e.g. Modbus)?
Do I understand this correctly?:
PLC can communicate with HMI via either discrete/analog I/O modules or Modbus protocol.
Thanks in advance for any reply (y)
There is a world of difference between the two.
The number of HMIs that communicate with a PLC using discrete or analog output modules is small, although not zero. The vast majority of HMIs communicate with a PLC over an ethernet or serial link using one of dozens of communications protocols of which Modbus is one.
Thank you Steve :)
I haven't had an opportunity to use the 1734-8CFG, but have seen it in different resources from Rockwell. I have used the 1734-VTM before when...
2,304
Is there any way to get a non-isolated IF8 CompactLogix I/O module to behave like one of the isolated IF4I modules? I'm wondering if I can leave...
8,296
hello sir welcome to the automation world. What is the main difference between 1747-SN and 1747-BSN modules in AB.If any one knows pleaae...
1,932
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,432
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,076
