Difference between Local I/O and Remote I/O
obi1987
Jan 2014
lahore
114
What is the difference between Local I/O and Remote I/O.If the difference just the area location then its mean normal I/O card can also be used as Remote.
Then how we can differentiate between Normal I/O Card,Flex I/O and Point I/O.
Local connects directly to the CPU
remote I/O is usually fed by some form of bus protocol and is locate away from the main CPU panel
Local I/O generally means that it's in the same chassis as the processor and is accessed through the back-plane.
Remote I/O is just that, it's just I/O with no processor that is remote from the local chassis. It will have some sort of remote I/O (RIO) scanner or adapter to handle the communications with the processor or remote I/O adapter in the local chassis.
Yes,regular I/O hardware can be used remotely.
Flex I/O is an Allen Bradley modular remote I/O system that can be used with most any AB platform and RIO Protocol. It can be readily identified by sight.
have a look at Visilogic (Unitronics)
the HMI is the CPU but the I/O expansion rack could either be remote or local
so depends on how you look at it
hello welcome to the automation world. my name is M.S.N.Rao. i am recently joined as a plc programmer. now i am in the beginning stage. my...
4,392
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,436
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,117
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
1,995
Hi Experts, Good day! What are the differences between PCS7 SIMATIC Batch and PM Control? Do you have any manual like "Getting Started "...
830
