difference between microcontroller, plc and microprocessor
How about this:
A plc is a system (sometimes refered to as a embedded system or it can be a piece of software running on a PC) that uses a microprocessor or microcontroller as one of the components
A microcontroller is a general term and can mean different things to different people and manufacturers use it as they feel fit. Often it depends on the context its used in.
As far as I know, Microcontroller used its internal memory when it is in "Microcontroller Mode". In "Microprocessor Mode", it used its external memory.
PLC is a hardware device which used Microprocessor as its processing unit.
- A microprocessor and a microcontroller are both chips while a PLC is a complete system.
- A microprocessor needs external memory- and I/O-chips, while these are integated in a microcontroller.
- A PLC consists of at a printed circuitboard, a microprocessor with external chips or a microcontroller, and interface circuits to communicate with the "ouside world", all this is usually mounted in a "box" with easy accessible connections.
What is the difference b/w a plc and a microcontoller since a plc contains a microprocessor, memory, interface ports like a microcontroller. and...
11,121
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,414
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,044
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
1,973
