Difference between PLC cables??????????
marsu1821
Apr 2005
Anybody could explain what is the difference between S7 200 cable and S7 300 cable for S7 Siemens PLC?
I know these two cables must convert data signals from computer (RS232) to PLC (RS485) in order to program PLC...but I don't understand why they are different in the catalog...
Thank you for advance
Hello marsu1821;
Both cables are RS-232 to RS-485 converters; but they also function as protocol converters. The S7-200 is programmed with PPI, and the S7-300-400 PLCs are programmed with MPI; there is a difference in speed (PPI is set at 19200 Bauds, MPI at 187,5 kBauds) and of frame structure.
By the way, the electronics of these circuits are one of the best guarded secrets in Siemens' world... do a search on PPI and MPI converters on this site, you will get an idea of the number of collegues requesting the same info as you.
Hope this helps,
Daniel Chartier
alright !
Thank you very much for these informations!
Moreover,I know it's difficult to find informations about this...
I will try to look after the circuit board in the cable in order to do another myself.But I think it will be very difficult.
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,844
Hi All, I am starting a project that contains RTU from SCADAPack 474. However, I have no experience with this equipment, I am familiar with...
3,219
Hello, Do you know what is the difference between the PID controllers PIDFF, PID1 and PIDP1 in a Schneider PLC? I have to modify a PLC program...
1,748
HI all, I have exported csv files from one of the application which was build in factory talk view. I'm seeing 1600 tags almost and doesn't...
2,345
I was just wondering why a setup would be referred to as a DCS rather than just a standard PLC system? I was on a site the other day and it was...
2,083
