Difference between tag and alias name.
mulderm
Jun 2003
Netherlands
298
Hello,
What's the difference between a Tag name and an Alias name created in the Input/Output
of a rack using remote I/O in RSView Studio ME?
I think I have a problem using tag-names and alias-names.
Can they use the same name?
Or can I use or the tag or the alias get to a object?
See attached files.
Also when I refreshed the tag browser I can't see the
created aliassen, why not?
mulderm
An alias is simply another name for an base object. Both the alias and the base tag point to exactly the same place in memory. As far as RSView ME is concerned they both refer to the same area. An advantage when using an alias - especially with fixed I/O - the base tag pointed to by the alias can be changed in the PLC. The RSView ME project which refers to the alias does not have to be changed to refer to the new base tag.
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,442
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,131
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
1,996
Hi Experts, Good day! What are the differences between PCS7 SIMATIC Batch and PM Control? Do you have any manual like "Getting Started "...
831
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,876
