Diffrence between 1770-XYB & 1770-XYC for PLC 5
flyers
Sep 2006
Amk
295
Hi guys,
Referring to the PLC5 battery. 1770-XYB is for enhanced processor series A & B. What is the latest series of enhanced processor available as of now? (Let's say 1875-L11B). If we have an enchanced processor of series C....then what battery should we use?
While 1770-XYC is for original processor series B & later. How about if the original processor is series A, then?
Thank you & Happy Merry X'mas to all! Hoho ho....
The only difference between these two batteries is the connector type that is wired to them. The 1770-XYB had a "snap" style connector (like the one on a 9V battery) and the 1770-XYC has a smaller stake-style connector, to prevent people from snapping on 9V batteries !
The only controllers that used the older -XYB are PLC-5/30, /40, /40L, /60, and /60L Series A controllers.
All PLC-5/11, /20, and /80 controllers use the newer -XYC. All Series B and later controllers use the newer -XUC. All Ethernet PLC-5's use the -XYC.
The current generation PLC-5's are Series F.
Ken,
Thanks for your reply.
" All Series B and later controllers use the newer -XUC." The controllers you mention is PLC-5/11, /20, and /80 or....?
I do not know AB has 1770-XUC battery, something new to me.
Sorry, typographical error. PLC-5 Enhanced controllers, Series B and later, use the 1770-XYC battery assembly.
There is a comprehensive battery application cross reference for A-B controllers in the Knowledgebase under Answer ID 16458.
Hi, We have a machine that we wan't to restart after power on if the emergency stop is OK. But if the emergency stop is tripped with the button...
21
6,610
For an automation project we need to program for the first time in TwinCAT (V2). The Twincat software and PLC control is new to me. Programming in...
5,170
Hi to all. We have a pH transmitter from Mettler Toledo (M400) that can be powered by 120 VAC or 24VDC. We also have a transmitter (M420) that is...
6,218
how to differentiate between rotary and linear motion exactly?any example about these two motion? i am starting working on packaging and tube...
1,936
I 'd like to know if force is different in s7-300 and 400 because I saw an article that said they are diiffrent but didn't explain about it
3,533
