Digital events in FactoryTalk View studio
Can you give more detail about what exactly you are trying to accomplish? Do you want to be able to see the events happen on a timeline? Adding those digital tags to the datalogger and putting them in a trend is probably the simplest solution.
i want to log whatever force commands i'll give to motor,valve in ftview in logviewer without adding it in FTview tags and display those logs values in ftview runtime.
The Alarm subsystem is probably the best way to do event logging in FactoryTalk View ME.
You can filter the alarms that are displayed on a particular alarm display object based on their trigger.
FactoryTalk View SE has the "Alarms and Events" subsystem where you actually put the ALMD and ALMA instructions in your ControlLogix, but Machine Edition doesn't.
So the first question is: are you using FactoryTalk View ME, or SE ?
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
263
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
455
I have a PLC type PM856 from ABB with some I/O modules and I get an error from the Digital Inputs model type DI801. The unit status shows error...
270
I am monitoring two BMXDDO3202K digital outputs for their behaviour, they are each for opening and closing, and so the on time affects how far the...
293
On the laser displacement sensor now connected to my PLC, the manual says 4mA=643 and 20mA=64,877. However, I checked with a Fluke, injecting...
898
