Dignostics Profibus DP
tmbotne
Jan 2003
I have a system with s7-314IFM oand two nodes ET200M Dist I/O.
I would like to run diagnostics on one of the nodes. It has two analogue inp modules with 8 inputs each.
I run Dp_SEND & DP_RECV. Then I run DP_DIAG for stationlist. This works perfectly.
Then I run a new DP_DIAG for diagnostics list. This is suppose to give message for new dagnostics data.
Afterwords I run DP_DIAG again for single station diagnostics. It gives 29 bytes of data, but it does not seem to update diagnosis data. I never get messages of Wire-brek e.g.
I have defined diagnosis properties i HW-Config.
How can I get live diagnostics of wire-break etc. in a simple way from the analogue-inputs on a ET200m??
I would highly appreciate all the help I can get!!
So i need to communicate my VFD (LS Electric iS7) with XGL PMEB module i successfully set the gsd file now i cant figure out how the data works...
64
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
227
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
104
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
127
