DIN Rail - Spacing of fasteners
ltrail
Sep 2003
Pennsylvania
25
Siemens, in their Systems Manual for S7-200, says that DIN rail should be fastened on 75mm centers. What has been the general industry practice? Three inches (a little more than 75mm) seems to close a spacing to me; one who has never constructed a panel before. Would some like to share with me their experience on this? Thanks :cool:
Yes, 75mm sounds a little overkill. A screw every 150mm or so has worked fine for me for many years. I use Omron PFP-100N aluminum DIN rail.
If you know you're going to attach something REALLY heavy, you can throw in an extra screw between the others. I usually attach REALLY heavy items directly to the panel though.
beerchug
-Eric
Am I right that, regardless of the manufacturer's DIN Rail holes (slots), I can have any distance between the mounting holes on the back of the...
20
10,163
I am looking for a fiber-to-copper media converter that is 120 VAC powered with terminals for placement in a small panel, so I can't use the wall...
137
I am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide. this is what I have now.... this is...
21
586
I have to mount a lot of slotted din rail and just ordered today. What is the best type and size of screw to use? Course or fine thread? I am...
20
2,488
