Direct Logic DL-240
jeb72
Jul 2013
texas
Hi, I need to copy the program from one Direct Logic DL-240 and upload it to another Direct Logic DL-240. I have the Direct Soft 5 software and I am wondering if this is a pretty straight forward process and are there, as with anything, those "don't forget to do this" things to watch out for? Any help is greatly appreciated.
It should be pretty straightforward, but I'll mention one thing. There are 2 types of uploads/downloads in DirectSOFT. One transfers JUST the program logic, while the other transfer the program logic AND all of the variable values (what DirectSOFT calls a 'project'). If you want to basically 'clone' the PLC, then you want to do the latter.
Also, you said "upload it to another Direct Logic DL-240". Uploading means FROM the PLC TO your computer, and downloading means FROM your computer TO the PLC. Make sure you know which way your going. Downloading a blank program to your 'already programmed' PLC will ruin your day quickly!
Uploading FROM the PLC TO your computer:
To upload ONLY the logic, select 'File--> Read Program--> from PLC
To upload the logic AND variables, select 'File--> Save Project--> to Disk
Downloading FROM your computer TO the PLC:
To download ONLY the logic, select 'File--> Write Program--> to PLC
To upload the logic AND variables, select 'File--> Save Project--> to PLC
Oh, and welcome to the forum!... :site:
-Eric
Thank you Eric, that was a huge help...I got the project from a good plc and was able to correct a big cooling issue on another piece of equipment.
In case anyone stumbles across this in the future, the 'upload' I highlighted in yellow is a typo. It should be 'download'.
-Eric
I have worked with Automation Direct line of PLCs before but it has been several years. I am looking to back up (save) PLC programs for my...
2,421
Hello, Wondering if anyone could possibly shed some light on an issue with a Direct Logic 205/DL 240 CPU. I'm having zero luck talking to this...
2,784
So this is my attempt at collecting and displaying data on a Cmore panel With a DL06. Each pair in my logic is the "Time total" or the TA15 and...
485
Hello, I am having some trouble trying to use Port 2 on the direct logic (250-1) for K-sequence. I am trying to use RS-232, I have a breakout...
555
I have a few o these controllers and had to replace a CPU. It looks like everything is there in the ladder including the registers for the port...
1,472
