DRATCLIFFE
- Join Date
- Apr 2004
- Posts
- 2
I AM WRITTING A PROGRAM FOR DIRECT SOFT 32
1.A PUMP SPEED CAN BE CONTROLLED MANUALLY AS A PERCENT BY TWO THUMB WHEELS SWITCH SETTINGS.
2.ANALOG OUTPUT PROPORTIONAL TO THE THUMB WHEEL SETTING. 00 ON THE THUMB WILL BE 0 VOLTS AND 99 WILL BE 9.9 VOLTS
3.IF THE PUMP IS RUNNING AT 75% OR HIGHER IT WILL TURN ON A INDICATOR LIGHT.
