DirectSoft wont save to disk..
elevmike
Feb 2004
Detroit, MI
4,012
Go figure...I'm on a site today and made a change to the program. I could save it to the PLC but not to the disk (laptop w/DS4 & Win98). I kept getting a diolag box that said there is a disk error or it's write protected..I cant figure out what's wrong. Likely something stupid, but am open for suggestions...
That's the error I get when I 'forget' that I can't open a project I stored on a CD-R... šŸ™ƒ
Assuming you aren't working off a CD, check the properties of the folder the project is stored in. It may have been accidentally set to 'Read Only'. Also check all the project files in that folder. Just select all, then right click and choose properties. You can look at the common properties of all. If any one of them is set to 'Read Only', you'll see a dim checkmark.
šŸ»
-Eric
Yes, once it goes on a CD-R, it gets flagged as 'Read Only'. What is equally annoying is that you'll get this error even if you simply try to VIEW the program on a CD, because it wants to save your last view when you exit.
šŸ»
-Eric
I am not a Automation Direct programmer. I have done a lot of RS500 I have the DS5 software and I am able to look at the program. I am reaching...
1,203
Hello, I have a couple of problems with the directsoft 6 software. I couldn't find a previous answer, and uninstalling and reinstall hasn't...
1,515
Hello all, We have an old AutomationDirect DL405 (CPU 440) PLC, and we've been using DirectSOFT 5.3. Since we are NOT upgrading this PLC for a few...
2,305
Hey everyone, Working on a system with a Koyo DL06 processor and it's my first experience with them. I have DirectSoft 6 and we got the program...
2,402
All, I have a program that I am adding the counter on Rung 83 (see attached). The reset logic is exactly the same as on rung 84, but I can't seem...
4,011
