Disabling of Windows key in RS View.
AB2005
Nov 2006
Lahore
321
Dear Friends;
I want to disable the Windows key of Key board during HMI running in RS view 32 works so that no any operator can open any program. Is there any idea?
In RSView 32 in the project tree there is a startup tab try some of the settings there but I advise you read the help files first as it can make the times you tourself wish to access windows not an easy task.
If your operating system is win 2000 or XP you can use desktop lock which is found from <Startup> <Program Files> <Rockwell Software> <RSView 32 Tools> <Win 2000 XP Desktop lock>
Again read the <Win 2000 XP Desktop lock help> file.
If Ctrl-Alt-Del functions, you won't need the start menu anyways.
PanelView +7 Series B ME station disables network adapter on panel when I downgrade to Rev. 9 or 10. Used to work before with the Series B panels...
520
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
1,045
I have an application that's in initial development. Two sets of 5700 racks, 4 axes each, separate power supplies, separate cabinets The two...
642
I'm working with Ignition 8.0.7 and am trying to enable/disable certain UDT members based on what PLC the UDT is originating from. I have a...
2,022
I haven't found this on a search of the forum or Rockwells KB. Is there a way to disable RSL/Studio5K from creating a grace period license? I...
27
5,550
