Disel generator synchonisation with plc
shirish
Mar 2009
Bangalore
20
Hello all
I want to ask can i use AB PLC for DG Synchonisation & load sharing effectively without using GCP/GCP/PL300/EASYGEN etc?
Thanks & Regards
Shirish Shrivastava
India
I would talk with your engine and alternator manufacturer and get a governor and regulator that will allow paralleling and load sharing.
Can you do it with a PLC - I suppose so
BUT
why take the time when engine governors and alternotor regulators have had this capability for decades. Why try to outdo the experts at it when they have forgotton more about it than most of us? The main hitch I see is getting the control signal to match an actuator in the governor and add a circuit to the regulator.
Even the antique units I ran on nuc submarine (69 to 73) had automatic regulator and governor (steam and diesel units) they could be paralleled and load shared - we ran split bus to avoid losing everything though.
Dan Bentler
Hello all I want to ask can i use AB PLC for DG Synchonisation & load sharing effectively without using GCP/GCP/PL300/EASYGEN etc?
2,172
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
102
Hello Experts, I am trying to create a SINE Wave generator and i cannot seem to make it smoother. I have done this before but i forgot the exact...
314
Hi dear forum, I need to create a test sine wave that so that I could check settling time in bidirectional inverters. Function that needs to run...
1,182
Hi, I have an older Kohler Generator/ATS controller that has a Schneider Electric (Modicon) Momentum PLC and has a Advantech HMI. I assume this...
725
