DL-06/ECOM linking to PC problem
DRS
Aug 2008
Wisconsin
75
Hi Forum.
Background: Been using Directsoft32 Ver.4 on a laptop with XP to program DL-06 PLCs with the ECOM module as my link to download the ladder programs (and life was good).
The problem:Got a new Laptop with Vista and while I can link to the C-More touchscreen displays, I can't get a link to the ECOM/DL-06 PLC. it does show up on the Net3 screen and because Vista does not support the IPX Protocol, under the Directsoft32 link editor if I select the UDP/IP Protocol the Ecom module also shows up on its list but I still get a link error.
My next step: After trying everything to manualing entering the settings to no use, I called Automation Direct's help line and was told it can't be done in Directsoft32 Ver.4 and that I would have to upgrade to Ver.5 for it to work.
The Question:Has anyone been able to link the DL-06/ECOM to a Vista PC using the Directsoft32 Ver.4 software?, and if so how was it done.
While it would be cheaper to get a USB to serial adapter(laptop has no RS-232 ports) and go in that way, I would like to use the ECOM if I can.
Thanks for your time.
Tommy
titoyabril
Thanks for the feedback, while it may not be what I would have liked to hear, it is what it is. And as you say it may be worth the extra costs for the upgrade to Ver.5. But after a trip to Radio Shack for a USB to Serial adapter to put a comm port on my laptop, plus a stop at Walmart for a short 6 pin phone line cord i was able to put together a serial cable for port1. While it's not as fast as the ethernet link it does work, so I can get this project done on time(Life is good again!). Now I have found one plus to this deal, I don't have to switch cables between the C-more and the PLC each time I want to make changes, ethernet works for the C-more, RS-232 for the PLC.
But once I get this project done I'll check out the upgrade, maybe it'll help get these projects off my bench sooner.
Tommy
Hi, I used to use my Lenze EMF2102IBCV001 LECOM a/B module to connect to many Lenze 9300 series servo drives. Now I would like to connect to Lenze...
519
Hello everyone, I got stuck on Communication with DL06/DL260 (H0_ECOM or ECOM100) through Modbus TCP. To make it simple I only read holding...
1,452
Hi everyone, Anyone know how to fix Lenze lecom A/B drive i get "LU Message" :huh:? Thank you all.
4,264
Hi, Anyone know how toinhibit lecom A/B drive ? Plzz
1,372
hello everyone, have someone here managed to get a Idec Pentra plc to work with a wavecom supreme 20 modem ? i want the plc to send me sms...
1,247
