DL06 D0-06DD1-D transistor replacement
iointerrupt
Jan 2012
Debugging Hell
I couldn't find any information out there on replacing a blown output transistor for a DL06 so I figured I'd post this here for others that make the same stupid mistake as me.
I picked up a D0-06DD1-D to do some home automation in my garage, and being my first PLC horribly mis-wired the outputs (pay attention to that +V terminal the manual barely mentions!) blowing 3 of the output transistors. Two of them fused themselves always on, and the third had a high resistance when operating.
The only marking on the transistors is "619", so the best match to them I could find was a Diodes Inc FMMT619, which has the same package, pad layout and marking. Mouser part# 522-FMMT619TA.
With transistors in hand, I used a hot air rework gun to pop the old transistors off, and then soldered in the replacements with a fine-tipped iron. Not terribly hard but it helps to be able to work under a microscope. After replacing them all the outputs were able to drive my relay loads correctly again.
One more warning, watch out for the labeling. The PCB marks the transistors as TR1 -> TR16, while your PLC labeling is Y0 -> Y23. The conversion to decimal is obvious, but I missed the fact that the Y labels start at 0 and the TR labels start 1. Ended up replacing a perfectly good transistor before I realized.
Hi, Mostly AB guy here with a little Koyo experience, but all of its digital. I get handed three analog I/O cards and asked to prove that they...
505
Hi all, I am making a test rig to be able to wire in any DL06 (or DL05) And create a HMI in red lions crimson 3.1 to test all the inputs and...
935
I have a Cmore screen which is communicating to the DL06 in BCD and need to create a timer that works in real numbers for a test, I simply need to...
2,163
I have a client that has many Automation Direct DL06 PLCs for a municipal water/wastewater system. When there is a power outage, one of the sites...
2,448
Hey everyone, Working on a system with a Koyo DL06 processor and it's my first experience with them. I have DirectSoft 6 and we got the program...
2,349
