DL06 Project Design question
dd40001
Jun 2008
Corvallis
Hello, I am working with a dl06 for a Fuel station project, I need to receive a few values over tcp/ip, log them and than based on those values send one or two back, What tools/code would you suggest to do this?
You say TCP/IP. is that MODBUS TCP/IP or ???
There are only a couple of ways to go about this project.
If it is MODBUS TCP/IP then it is fairly easy, you need an H0-ECOM100.
If you are looking at some more generic type protocol, then you will need a H0-ECOM or H0-ECOM100 and HOST Engineering's Software Development Kit to write a driver.
One other option would be to use an OPC Driver as the software to interact with the sending device.
Give us a bit more info to go on and we can help steer you in the right direction.
Since I don't know what kind of device you are talking to, I can't really give you a solid answer.
If you are talking to a PC, then the answer is maybe. If it's anything else, then I'm not sure.
It should work, but I can't say that it will with certainty. As long as it adheres to the MODBUS spec all should be well.
Hi, Mostly AB guy here with a little Koyo experience, but all of its digital. I get handed three analog I/O cards and asked to prove that they...
505
Hi all, I am making a test rig to be able to wire in any DL06 (or DL05) And create a HMI in red lions crimson 3.1 to test all the inputs and...
935
I have a Cmore screen which is communicating to the DL06 in BCD and need to create a timer that works in real numbers for a test, I simply need to...
2,163
I have a client that has many Automation Direct DL06 PLCs for a municipal water/wastewater system. When there is a power outage, one of the sites...
2,450
Hey everyone, Working on a system with a Koyo DL06 processor and it's my first experience with them. I have DirectSoft 6 and we got the program...
2,349
