DL06 with CTRIO for flow issue......
XtremeIN
Jun 2005
Indiana
217
Hello all,
I am having some trouble figuring out how to use a H0-CTRIO card in a DL06 to calculate flow. I have the card set up as an up counter and it is receving the pulses from the Halls Effect type transmitter (flow meter). I know how to use the scaling wizard the issue with that is the end user needs to be able to change the K-Factor when a flow meter goes out and is replaced. I also have X0 set up as a High Speed Counter for the same reason (I need to moitor three flow rates). I use X0 to increase an INC box then use basic math to calculte GPM. But for some reason I cannot figure out how to get the CTRIO to work, the big differece is the CTRIO uses Vmem not a descrete input........ any help would be great.
Thanks,
Micheal
edit..... One way I thought about doing this was using the Count Complete Capture Bit from the CTRIo like the X0 input. My problem is I do not know which bit it is. The manual says it has a 20.0 Vmem offset......anyone know what that means?
Hi, I am a complete newbie when it comes to PLC programming and would love some help. I am trying to configure a machine consisting of a DL-06 plc...
1,669
Hello all, I am currently trying to write a program that will use solenoids to push buttons on an interface board and a stepper motor system to...
2,194
Hi, Mostly AB guy here with a little Koyo experience, but all of its digital. I get handed three analog I/O cards and asked to prove that they...
505
Hi all, I am making a test rig to be able to wire in any DL06 (or DL05) And create a HMI in red lions crimson 3.1 to test all the inputs and...
935
I have a Cmore screen which is communicating to the DL06 in BCD and need to create a timer that works in real numbers for a test, I simply need to...
2,165
